1986 BUICK GRAND NATIONAL
COMPLETE MINUS ENGINE
ASKING 15K OBO
CONTACT LUIS AT 310-923-4377
THIS BUICK IS WORTH EVERY PENNY
I WILL TRY TO LIST EVERYTHING BUT I KNOW I AM FORGETING SOME STUFF
I INVESTED A TON OF MONEY IN MY BUICK PLUS TIME.
exterior:
Two tone paint job
frenched quarter windows with custom made glass
all trim around windows powder coated
gnx fender vents
front fiberglass bumper
rear steel bumper bolts welded and shaved
billet specialties wheels 15 x 4 fronts and 15 x 8 rears
28" tall front m/t sportsman tires drag radial rears
chassis:
Chassis was removed, boxed in , gusseted all rear control arm holes, boxed rear lower control arm brackets, factory welds polished and powder coated fine wrinkle black, poly body bushings
drivetrain:
no engine
4l80e built transmission (re done 6 months ago has 1 pass on it)
rossler trans brake
modified valve body
deep cast pan
pro torque 3600-3800 lock up converter (serviced 6 months ago with new clutches)
pro ratchet shifter modified to fit original console
3 1/2" aluminum driveshaft with big u joints
currie ford 9" with big drums, detroit locker 3:55 gears
h&r bar
rear airbags
custom rear springs
qa1 billet adjustable shocks
Edelbrock upper and lower adjustable control arms
global west tubular front upper and lower a-arms
aerospace components front brakes with billet calipers
vented cross drilled and slotted rotors
earls braided lines
hotchkis steering kit
center link,drag link,inner and outer tie rods billet hex sleeves
quick ratio steering box
fuel system:
Supports 1300 hp
aeromotive eliminator pump
aeromotive billet 10 micron pre filter
aeromotive billet 100 micron after filter
aeromotive fuel pressure regulator with rising boost port (the big one)
12 an earls braided line
10 an earls braided return line
all black an fittings
stock location fuel cell with factory fuel level sending unit
cooling:
Aluminum radiator
dual spal fans
INTERIOR:
CLEAN ORIGINAL INTERIOR
STEWERT WARNER MAXIMUM GAUGES CUSTOM MOUNTED
2 GAUGE PILLAR POD
5 POINT ROLL BAR WITH DRIVER SWINGOUT (RETAINS REAR SEATS)
^^^^ THAT IS A DRAG RADIAL
ASKING 15K OBO
exterior:
Two tone paint job
gnx fender vents
chassis:
drivetrain:
no engine
rossler trans brake
modified valve body
deep cast pan
h&r bar
rear airbags
custom rear springs
earls braided lines
fuel system:
Supports 1300 hp
cooling:
Aluminum radiator
dual spal fans
INTERIOR:
2 GAUGE PILLAR POD
