Boostin TA
- Aug 27, 2005
I was wondering everyones thoughts on the new MAF translator available. I am long overdue to get outta the stock maf sensor and upgrade to a translator and lt1 maf sensor. I was wondering if anyone has the new style translator and the pros and cons of it? Also how hard is it to tune? I have a alky system as well and figuring out fueling has always been a problem. I will have it dyno tuned and have a custom chip burned for it. Does anyone have a good base line program or set up they can share with me. Unfortunatly I have done a lot of mods to the car but it is way out of tune and I have no good base point to start from. I currently just have a commander chip in the car with I believe 20-21 degres of timing and only running about 15lbs of boost and seeing 0-4 deg of knock. Running a PE 63 turbo 60lb injectors, smc alky, polished ported stock heads and intake with larger valves, THDP with open dump, built trans with 3000 stall, 3.70 gear in the rear, When I did a baseline dyno pull at 14lbs of boost It pulled 362hp and 480 torque. But my wideband 02 readings were all over the place started rich..went a little lean then back to pig rich... it was about 10.2 fuel/air ratio and throws alot of black smoke. Fuel psi is set to 45.
