Scott89TTA
- Jul 12, 2005
Do to my current financial/divorce situation I had to put the installation of the Currie 9" I have on hold for now...blew about 6 teeth off ring gear last Fall with 16 psi transbrake launches and a half dozen 1.48 60ft times After adding up the cost of new axles, gears, drive shaft and assorted parts totaling over $1,000 I just couldn't justify spending that much on my car right now. After doing some searching 9bolt.com seemed to be the only option for gears...used gears at that ranging from $220-$270 plus shipping from Australian almost puts me 1/2 way to my original cost of finishing the 9" install. Until I found JTs Parts & Accessories, Justdifferentials.com and Nitro Gear & Axle Home - Nitro Gear & Axle they just recently added a 3.70 gear set for the Australian Borg-Warner 9-bolt 7.75" rear for $175. I talked to the guys on the phone and they were awesome. Since I am now running 28" tall tires the 3.70 gears should workout perfect. So far after a couple test drives going from the stock 3.27 to the 3.70 gears the car feels nice and turbo seems to spool quicker...plus it seemed to correct my speedometer according to my GPS! So the big thing for me was to finally get the car back on the road after nearly 9 months...the 9" will go in when things settle out but for now I'm crusin' again!
