jpwalt1987
- Nov 9, 2003
Well guys I finally made it to the track after a 10 year dry spell. It was hot and humid tonight in Evadale TX. 80* and probably close to 80% humidity. I had been playing with the SD2 chip for about a week before this. Got all my fuel corrections close at wot. The first time I went to do a burn out the car killed and wouldnt restart. Holy hell was I pissed. Turns out it popped the FP/INJ fuse. Why, I dont know. Got it started and waited forever to make a pass. Did a burn out and made a pass and it spit and sputtered and popped and banged and killed when I let off of the gas. Popped the same fuse again. Wtf? Got it back to the trailer and decided to switch my secondary pump to run all the time instead of on the hobbs switch.
I also take out some fuel because my wot af correction was pegged at -10%. Boost is set at 24 psi and timing at 19*. AFR target of 11.0:1.
Car goes 10.92@125. No knock. 2nd pass is a clean pass.
3rd pass was garbage. Spun every time I got on the gas.
4th pass I turned up the boost since I wasnt seeing any knock to 27-28. I increased the fuel @wot from 135 to 137 on the SD2 and added 1* degree of timing. I tried to launch on more boost than the second pass(4psi) so I started building boost on the prestage light. I could feel the car pushing so as soon as the stage light lit I engaged the transbrake the put the pedal to the floor. I red lit this pass from being anxious. Released the brake and the hit actually caused my foot to let off the throttle for a split second. Rookie mistake. Felt stupid. Oh well.
The car hooked and felt strong. Tried to hit my shifts just right. Did pretty good on that.
Result- 10.70@130 with a terrible 60ft.
I honestly feel the car should be wayyyy faster though. I think the convertor isnt correct for my combo. I will upload the powerlogger file tomorrow to see what you guys think.
Here is the combo:
3.8 109 block built by DLS
All forged bottom end
Ported GN1 heads with PAC 1203s
218/ 218 .540 lift dls cam
PTE front mount
Alkycontrol single nozzle
Dual DW 300 pumps on hot wire and volt booster
SD2 CHIP
BorgWarner6668 turbo
80 lb injectors with drilled stock lines
Th400 with transbrake
ATI convertor 10"
3 1/2 DP made by me
Dual 3inch cottons exhaust.
Probably forgot something in there too.
The car was at 76% duty cycle on the 80s and the meth kit was on 7.5
This was on 93 and alky.
Anyone have suggestions or is the mph on par? The car weighs right at 3700 lbs. That figures up to be 625 hp on the HP calculator. Adding 3 psi and 1* of timing gained me 5mph and approximately 75 hp. Am I way off base?
Thanks for any suggestions.
Here is the combo:
PTE front mount
SD2 CHIP
ATI convertor 10"
3 1/2 DP made by me
