TR Custom Parts
Mark Hueffman - Owner
- May 25, 2001
Billet Vacuum Block Before knocking it, think about it...you eliminate dealing with the steel lines and the wonderful attaching tab on the manifold, you can run a vacuum line right to your fuel regulator right from the drivers side as well as having an extra port for vacuum brakes. Includes straight fittings as pictured but you can get creative with angle fittings if you want. Not to mention eliminating 5 potential vacuum leaks by not having the short lengths of hose that connect the stock block to the steel hoses. Just something a bit different that works. Billet aluminum and made in the USA.
