Z
zombie
Guest
Well here's another question . I'm in the process of getting my car running and just got a new John Craig Turbo (te 45 a) and oil is coming out of the exhaust side of the turbo and a little out of the other side . I'm using an 85 block and had to run the oil return line to the passenger side block off plate . The oil return line is -8 braide line that runs over the water pump and down to the block -off plate. is it possibility that the oil is getting past the seals because it's not draining correctly or is it that the seals are bad ? The car is still on jack stands and hasn't even been over 1500 rpm the turbo hasn't even made boost . My question is how easy seals blow . And how much pressure does the the return line experience . Yesterday the car ran for 20 minutes at 1500 rpm and wasn't smoking when I shut it off was just running fat . Just need some feed back . { car has fresh motor , new cam , new oil pump , fr. cover , ect......} THANX
