Video of 10.34 biatch! - Photobucket - Video and Image Hosting
Having problems with my 60 ft. 1.65 isnt going to cut it!
SignUp Now!Video of 10.34 biatch! - Photobucket - Video and Image Hosting
I think I should be better then that, but who knows!! It went 6.60 in the 1/8th at 107.5 at only 21psi. I just need to lean it out on the brake and build some boost and the rest should take care of it self.
Ive got hr rear sway, air bags, hr upper and lowers.
Are those you mustangs too? If so what do they run? The motors in them are awesome!
Yes those are my mustangs. Havent been back to the track yet with them. Foxbody should run bottom 9s high 8s.
Nice pass even though the 60' was crappy! You mention the turbo won't spool.. Do you think it's possible you may need to lean out the tune a bit on the bottom end or maybe the converter is too tight?? What stall converter are you running??
Thanks for sharing
You hit it right on the head!! I am going to lean it out and if that dont work I will look at the convertor.
Why the HR bar, and the air bags??
Bout all the bags do is change the spring rate, and tend to make the rear end "basketball" bounce. The bar, control arms, a good set of shocks, is all you need.
