New to Alky
Clark6
Hi Razor, Or Anybody Im Suppose To Get My New Alky Kit This Week & Gonna Try To Install It, Will The Isoprophyl 70%to 30% Work Ok For The Street & The Denatured Alch. For The Track Or Serious Race Be Ok. Also Do You Have To Put Lube In The Tank For These Or Is That For Just Meth. What Psi Is Razors Pump 60 Or 100psi?
Some of these questions depends on who's kit you'll be getting. There are as many on the market place now days.. so its hard to keep up with everyone.
Just like cars, some are diesel, some are gas.. you cant use the fuel from one in another.
So specifics as to whose kit may help. I generally dont like to give suggestions on other MFG systems since it steps on their toes.. and I need to keep peace with everyone. To this, I suggest the person getting the information straight from the Source of who made it.
Part of the purchase of one of these systems is the technical resource behind it. Hence why I dont interfere with other systems and their methods.
If its my system, i'll do everything in my power to help.
of course julio its your system i, talked to you thursday i think,,, from Georgia
Remember i said ive learned more from you in 10minutes of talking to you about things like pullin your heads off checking the broke exhaust valve you found, to ttweek chips to, boost creep, to tire sizes remember i asked did you go to reynolds this year, you said you made one pass & heard a flutter:)
Others may be well indeed but im not takin any chances on some one elses kit. Im not all that smart but i do learn fast. LOL.
Remember i said ive learned more from you in 10minutes of talking to you LOL.
in the 10 minutes you talked to him you have found out everything he knows :eek: :p nice simple system :cool:
I never make guesses on this stuff.. appreciate the business.
As to alcohol.. methanol is my number one choice. Look on the very first thread it says "Methanol Sources" do some reading through there and see if you can come up with a source.
If its not available to you, then the other alcohol to use is denatured alcohol(home depot, lowes, paint and hardware stores).
If you plan on rubbing alcohol, then buy the 91 stuff.. the least amount of the water, the easier to dial in the car. Methanol is the easiest to "figure out". Isopropyl is expensive compared to the others.
Lastly, pretty much any of the above alcohols can be used, including mixing thereof with water if your boost levels are relatively low. Example 20-22 PSI. The issues start when trying to go higher in boost with timing, leaning out air fuel, etc. Your knock sensor will tell you what the car likes.
ok thanks and as for the lube?? with the meth.... what kind or how much to use per oz or gal.is it already in the instructions with the kit or just do a search...thanks for responding & i will let you know how it goes.
THAT WAS FUNNY GRUMP, I THOUGHT YOU TWO WERE FRIENDS LOL.
I have no friends :eek: :p ...well none that talk to me :wink:
Thats why his screen name is Grumpy :tongue:
No lube please.. nice and dry :wink:
