I had the same goal as you do, not sure on your budget but like Clint was saying, it really is less expensive to do the engine build correct the 1st time than to do it twice. I took my time and gathered used parts, billet 6262 turbo, Champion iron heads, ok maybe that's it for the used parts, but every little bit adds up. Pretty much everything else is in my signature, but slow and steady will get you there. Getting back to your situation, while the motor is down, put your money in that , so you don't have to pull it again. Most other upgrades are bolt on's, consider a girdle or two billet center caps for the crankshaft, ARP hardware for assembly, roller cam, heads ported with performance valve job (champion cnc heads are better). If you end up needing pistons or you bore it over size, aftermarket pistons; will need to get the rotating assembly balanced. Alright I think I spent enough of your money...... same with the tranny, cheaper to get the best one right up front than a mid grade one, just to have you over power it in 1yr and then spend the money on the one you should have bought to begin with... oooohhh I would have saved $$$$'s if I would have done that... By the way the picture of your car looks sweeeeeeeeeeeeet !!!
Chuck
