I just purchased an 89 TTA and I am having some idle problems. Re-setting the IAC and adjusting the TPS didn't seem to help. BLM's are close to 128 at idle, IAC is low to mid teens. TPS is at .44 VDC The oxygen sensor is transitioning really well. No trouble codes...everything looks "right" on the scan tool. Sometimes the car will stumble a little when accelerating, but once the boost starts to build, it smooths out. I hooked a timing light up to each individual spark plug wire. Some of the wires had a definite "miss" as I was watching the light. I installed new spark plugs and spark plug wires tonight. It starts much easier, but the rough idle is still there. I hooked the timing light back up to the wires and you can still see the "miss" when you watch the strobe. It seems like it is worse on the right hand cylinders (it was like that before the new plug wires too). What do you suggest I change next...the ignition module or the coil pack? I don't have a tester or access to spare parts at this point. Thanks in advance!
