Fair enough...Boost231's post has me a little concerned about one more WOT run, so I would feel so much better with a known chip and injectors.
You should be concerned. You already have a chip and injector combo that is proven to work on your car. There is no reason to think that they are the cause of your problem. You have serious vacuum leaks that would likely be the cause of your problem. When you fix them,they will make a dramatic difference and you didn't check WOT fuel pressure yet.
