SignUp Now!what hotwire kit did you get?
Also i would check the pump just to make sure its up to task. i wouldn't want to run a stock pump or old pump IMOP. just good to know whats in the tank.
It's wire,a relay,and a fuse holder. What makes it better than the Caspers?Awsome, Racetronix makes the best hotwire kit IMOP.
I had a Caspers kit, hell i have had a few different kits. Not saying they didn't work but,
what i like over the caspers is
Build Quality, quality of connectors, connections, wire, heat shrink to name some.
Racetronix seems to use a better quality wire with thicker gauge wires as well.
The tank lip ground is built into the pump and chassis ground
I also like the locking tab they have as well.
Overall i think the Racetronix kit is nicer and built better. Just my opinion, both will work fine. Also another issue is grounding but thats another topic
^ Nothing wrong with building your own thats for sure. We can start another topic on hotwires if you like. kinda goes in line with the ground topic that was talked about a few weeks back.
Anyways back to the orignal topic...
Glad to see you r learning like the rest of us. I love my tt chip and injectors. I also have the same hotwire kit. I would rather spend a little like you to know for sure than to build a new motor. I also have learned over the years on here that there is always someone who thinks there way or stuffnis better no matter what you say or do
^ his turbo is in his sig. looks like a GT6131E, from the looks of his other mods and miles on the car im going to guess under 23psi
6131e and 21 for boost. Af 10.8. 21 degrees of timing. I am on the safe side..
Ttype6 said:That's actually quite rich for that amount of boost. It doesn't need to be that rich until boost gets much higher. 11.0-11.4 would pick it up a noticeable amount. E85 is wonderful stuff. Why did you decide to go with it? I'm sure it wasn't for gas mileage.
I live in Arizona so its hot and all we get is 91 which sucks. Like I said I like safer than sorry especially on a low mileage car
