slo-joe55
- Jan 12, 2007
Hey Guys,
Looking for some feed back. New engine build was originally built for TSM class. Car is now set for street duty. Engine: all forged internals,roller cam, ported alumin heads, ported intake, 83lbs injectors, etc. Watchdog is a old Fast Bank to Bank system. Still 231cu.in. Turbo considered @ time of build was a PT70GTQ. Trans: completely redone, including AC 9" NL 3800 convertor. Rear steel axles, HR anti-roll sway-bar, bilstien 50/50 shocks, new stock springs, new lower after market control arms,after market pinion snuber. If it make any different Block is a hi-nickel block. Now the turbo on this setup presently is a PT61, which I had before the build. I am looking for a turbo to get a 3600lbs car down to low 10,s and keeping boost levels no higher then 20 or 21lbs. Is this possible? And if so, what turbo?
