Apr 5, 2013 #1 K KCODE Member Joined Aug 1, 2012 Messages 229 I just removed a crappy turbo from my 86 GN. Replaced with a TE 44. Everything smooth until ooops. The intercooler sits lower than the turbo so I can connect an suggestions. Im new to this.
Apr 5, 2013 #3 K kidglok Balls Deep Joined Oct 10, 2010 Messages 2,278 If you loosen the bolts on the cover you can rotate it so it lines up.
Apr 5, 2013 #4 I ikle Active Member Joined Dec 18, 2009 Messages 1,004 kidglok said: If you loosen the bolts on the cover you can rotate it so it lines up. Click to expand... X2
Apr 5, 2013 #5 T TURBOPOWERED68 David Joined Jan 31, 2006 Messages 8,819 kidglok said: If you loosen the bolts on the cover you can rotate it so it lines up. Click to expand... X3
Apr 5, 2013 #7 K kidglok Balls Deep Joined Oct 10, 2010 Messages 2,278 KCODE said: Yeah thanks. I got it now. Newbie. Click to expand... just be careful when you tighten it back, the heads snap quite easily.
Apr 5, 2013 #9 M mapmaker Active Member Joined Mar 6, 2011 Messages 109 Glad I check the site daily to see what I can learn. I just installed a new 60-1 last night and have the same issue. Thanks everyone.
