New turbo or not
okc87gn
Well let me start to say what I have ta49 009inj. Red's chip thunder fab incooler, converter is 9/11 3000 stall. stock cam and heads, thd down pipe and scan tool, New Fuel pump. I would like to run in the 11.30 time frame. I haven't had the car on the track yet because of general problems in life. The car pulls good but to me just not hard enough, Use to have a car that ran 10.10. Love this car because I can drive on the street. Do I have the right combo to make this happen. Or what do I need ????????
:rolleyes:
you have enough to run high 11's on high boost, slicks, and race gas.....to go faster will require more than just another turbo
Well if I change my Injectors from 009's to the 50 size and leave the TA49 alone would that help me get to the 11.30 bracket. What are some of the 50's injectors being used.:confused: What else could be done to get to the time that want.:D Thanks for the help .
Well you got the converter so I would just add TE-61 and some ported heads that should get you there or faster.:D Your injectors will get to low 11's but msd 50's would be nice.
