new4.1 setup!!!!
fmturbo
TURBO TECH
what is the best fuel pressure for 42.5 lbs injectors......and 25 of boost!!!!!!!!!!!!.......i am trying to hit 11.00 ...... need some help with this new setup is......... 4.1 block ......30 over ,,,,,1.65 roller rockers ,,TE51 turbo ,front mount pression intercooler..hot wire and 340 pump 160 stat....ultra chip adjust upper and lower...3.42 gears .....anybody has try this!!!!:cool:
man, honestly, i don't think you should try that with 009's! that big motor needs fuel, i mean you would just have to make a few blasts and look at the WOT Blms and see what the car is needs. If your BLM's are higher than 128 then you need more fuel, that's when you start adding fuel pressure. that way the computer will gradually start pulling the Blm's down to where they need to be (128 ). that's just my two cents though.
