stroked94z
- Jun 23, 2007
I've just starting tuning a Gen6 setup on a 383 LT1 powered Camaro w/ a fairly large cam. I've read the tuning manual and book, but still am a little confused when it comes to the fuel map. The setup has a narrowband O2 sensor, and from what I am reading, it says that in closed loop, it is always going to adjust back to 14.7 and that your goal is to get the base fuel map calibrated so that it is correcting as little as possible. I have a friend with a very similar setup engine and cam wise, but with a FAST wideband setup. He says that his car runs best a little richer than 14.7 in most areas of the map. He is able to simply command the desired AF ratio. Is there a way for me to richen up certain areas of the map, but still run in closed loop, or do most people just run open loop all the time and set up the fuel map accordingly?
