Hi everyone,
I tried the demo file and other suggestions as listed in my previous post
http://www.turbobuick.com/forums/showthread.php?s=&threadid=54073
but to no avail. I changed the necessary settings in the file to those of an SBC and also changed the Crank ref angle to 50.
The engine will crank and spark and combustion will start. However, it will not continue, meaning it just dies right away. I messed with various settings in the VE table up and down and the plugs showed either rich or lean. I'm at a loss here
Once I get it to where it'll almost start, what can I do? Adjust the cranking vs. CTS table? Start IAC vs CTS?
In closed loop parameters, if I check the closed loop enable box, that will force closed loop based on the rpm settings, right? And if unchecked, it will never run in closed loop? I have the closed loop rpm at something like 3700 rpm, with the box enabled. Should I uncheck the box completely?
One thing I noticed is that my fuel system is not holding pressure after the pump primes. Regulator seems ok so it must be the injectors (RCE) or pump (SX). I changed the prime settings to 25 seconds so that there was pressure when I attempted to crank but still no luck.
Help me! There is a tuner 30 miles away but I SHOULD be able to get this running myself, right?
Spark is at 0 deg (went up and down from 0 to 20)
Crank ref angle at 50 deg
Voltage drops at cranking to about 11
FAST and MSD 6AL are hooked up directly to a distribution block coming directly from the battery. And later in the day I was running off a jump-starting battery charger giving me 13 volts or so.
No external fuel leaks.
The fuel pressure problem is bothering me but with a 25sec. prime, there IS pressure when I crank it...
Thanks in advance,
Owen
Thanks in advance,
Owen
