mustangracer42
- Aug 19, 2002
I just got my car running the other day and Im having some problems getting the O2 correction to keep the "actual" af ratio to match the "desired". The problem is only at idle up to 1500 rpm. I have a desired af ratio of 13.5, the closest I can get for actual is 12.4-12.8 and that's with the correction maxed out at 25%. Like I said I'm a newbie with this stuff so if you guys can give me a few areas to start playing with I'd appreciate it.
I've already started messing with base fuel pressure and it doesn't seem to help. I've gone from 50# (recommended for my setup) down to 25# and always seem to have the same 25% O2 correction factor.
Jeremy
Jeremy
