Newbie needs some advise
etnrice
I have a 87GN with some minor upgrades and am looking to go to the next level. The car just turned over 100,000 miles but seems to run strong. Here is a list of upgrades that I know of:
green stripe injectors
high perf. fuel pump w/ hot wire
adj. fuel pres. reg.
kenne bell ram air w/ K&N
ATR stainless cat back exhaust
several differnet chips
kenne bell shift kit
torque strap
air flow distribution plate
160 thermostat
2800 cfm fan
scan master
I am looking for low 12's high 11's so any info on what turbo, downpipe, converter, intercooler, ect. would be great. I sold my first GN about 4 years ago so I'm kind of out of the loop as far as new products and tech. Thanks for the help.
If you have not run the car yet, dont add anything to it. Watch your knock counts and go blast it. You can get some very good times with what you have just by hooking up and tuning your combo.
Then after its tuned and you are not satisfied with your times(who is?)... step up your combo with a bigger turbo. But remember...everything is relative and your motor is just an air pump, so injectors and exhaust upgrades will have to be next to see the difference.
