newbie powerlogger user and a few ???'s...
trbojo
'Stang Stinger
1) auto quick save is what it implies? automatically saves a log after a run with no additional user input?
2) recording trigger....i'm using tps...i set voltage higher than default, at 4.00..is this ok?
3) min record sec. i also set this higher than default, to 20 sec. , to give time for burnout, stage, and launch....is this enough time, or should i go higher, or use a different trigger?
i think that's it for now, but i'm sure i'll have plenty more.....
Just use the spacebar as a trigger, then you don't have to worry about if there was enough time to capture your burnout and what-not. As far as the TPS as a trigger set it to what you want. Do you want it to record with 3/4 throttle? then aim around 3. Do you want to record half throttle runs? then aim around 2. Only WOT runs? then 4 should be good.
Lastly I don't remember how to use the auto-save, but I had it set up before and it worked well.
