See Picture, is this what I need to do? I have a MAF translator and a Ls1 Maf, I believe I just need to get the coupling and a air filter, but what do I do with the air temp sensor? Thanks
You can either poke a hole in the filer neck for the ATS, or just let it hang close to the filter so it's exposed to the same air. If you ever put on a cold air kit that draws from outside the car, I'd recommend putting it in the airstream, but with an underhood filter, They'll both be in the same air.
You'll really like having that LS1 sensor. It'll make your car feel like a different animal.
I can fix you up with a coupling if you need me to. I don't have orange though, just black
