motor break down... is in my sig.
Dropped this “fresh” the engine in the car and after a lengthy break in, immediately blew both head gaskets at 18* timing and 15psi. Not sure what happened here. I was running 11.8-12.0 AFR's. No knock, no detonation on plugs. I'm told with alcohol fuel (I run e85) you skip the detonation and go straight to pre-ignition. This may have been the case. I've since replaced the OEM HG's with SS shims and studs.
In a mad dash I made it out to the last few hours of the local test'n'tune this weekend. With a overly conservative tune and surprised myself.
I mixed my own e85 this time around to assure I had a decent blend. Also since the last incident I use a fuel/ethanol percentage tester to verify 85% ethanol mixtures. At 14* WOT timing, 10.0-10.2 AFR's and 19psi I went 10.79 @ 128. That was with a weak foot brake launch of 1.67. Later I played with the t-brake a bit and managed a new personal best 60' of 1.51 on a 9-10 lb brake launch. This was with 19psi in a 9" x 26" slick. Lots more left there. Unfortunately I had issues blowing the charge piping off at anything over 19psi. So I didn't get to turn up the boost.
At this point I'm thinking the timing on the car is off somehow. I do have a MAF translator II installed. Timing settings are straight up. Using turbo tweak chip to control timing only (set at 103). Grounded the aldl pins and I'm seeing 13* or so at the crank. I'm stumped, yet happy.
(Signature doesn't seem to be updateing?)
86 Rx-7 GXL Hybrid 86 Grand National motor. (2820lbs race weight) (9:1) TRW pistons, Webber ported IRONS, Turbo Tweak E85chip,Translator plus,PT68 turbo,CPT 9" Competition converter, Powerglide, 83lb inj's, Magna Flow 650HP fuel pump, 218/218 flat tapp. cam, 10mm Race Wires, Adj. FP Regulator,RJC PP ,FMIC 18x32 spearco bar&plate, Custom 3 inch mandrel DP, postons X-over pipe. deltagate WG, 3.27 gears, WB 02, 26"x9 slicks,
