Coelacanth
- Jul 7, 2014
Now that I was finally able to install a 3.5" LS1 MAF sensor, AXiS interface & chip, and dial in the IAC and TPS settings, I'm thinking my next important ugrade needs to be a fuel pump & hotwire kit. I'm running stock turbo & injectors for now, but the injectors may be upgraded at a future time. Whatever I go with for a fuel pump should work with what I have now, and possibly 42# or 60# injectors and wake up the stock turbo by adding a manual boost controller. I would say my goals are modest: 12-second car, on a budget where I get the most bang for the buck. I'm also restoring a 1970 Charger so I'm always trying to stretch my car budget as far as it'll go.
I'm monitoring detonation with ALDLDroid and Bluetooth ALDL adapter.
Would you all agree that a fuel pump & hotwire kit is the best logical upgrade step? At least it's not overly expensive, I might even be able to do it this summer.
-What fuel pump should I go with, that will work fine with what I got, and also work for a mild injector & turbo upgrade. I might not even upgrade the turbo, I could just add an adjustable boost controller.
-Is the Racetronix hotwire kit a good package?
Thanks for the advice.
