Eric Stage I
TurboTweak Guy
- May 25, 2001
Why do you prefer projected tip?
In general, projected plugs are better in every way for 99% of us. Closer to the center of the combustion chamber (less timing required, helps with detonation), wider heat range keeps plugs clean (hotter at low RPM, then cooler at higher RPM), etc.
However, with a higher HP car, say 150hp per cylinder, some may need to consider a non-projected plug to back the tip out of the war zone, even if it is less efficient. In these cases, you may be running race fuel, and changing plugs often anyway.
