Nitrous users need adv.
galoush
HWY2HELL
Im thinking of running a 50 shot mabe 75 with the NOS kit . I have a sumped cell , Paxton pump (like the Aeromotive pump) with # 8 line to the rail . In the cell im using c-16 117 octane gas , 009 injectors ,adj reg. Stock tank with 307 intank but i dont plan to use that with it . In the car i have a valve to control boost marked which has worked well , with a racegate . Ive run up to 23 psi on my stock motor , no o rings etc , so i dont think going higher with the boost is a great idea . Im thinking of going the Nitrous route and staying at 16psi . Also im running reds 93 chip with 20deg timming . would i get more bang from the juice with my setup , can i spray it the whole 1/4 , Is the timming to high with the chip i have ??? On my last trip to the track i went 110mph consistantly with the good gas and 23psi on that chip , also im using a TA49 and stock bigneck I.C . thanks for the input .:)
On a stock Gn (stock turbo, intercooler, converter) with 009's and 75hp shot of nitrous, chip with 19 degree timing and Mickey et's I would pull 12.3's. I have started doing my own chips and think flat 12's should be obtainable.
With a good fuel system, not to much timing I would think you could better your signature time.
I would recommend some way to monitor knock, go one colder on the plug, and start about 16lbs of boost, go with a wet system I like to the NOS system.
Chuck
LOW 12'S ARE NOW PROBLEM , AND THATS WITH A COMPLETELY STOCK MOTOR. PUT IT ON..... PUT IT ON;) :D :cool: :)
