SignUp Now!The CFM rating of turbos, is this the compressor side or the exhaust side or combo of both?
ks
This is the question, adding air may be easy.. getting it out.. thats the problem. Hole on stock turbo exhuast housing is very limited. Maybe with an external gate setup that can be better setup, vs the small puck hole that has the flapper.
Agreed. I would have like to have seen how much you would have picked up on top of the 27psi boost with the 35 shot. Id think youd still gain more than the rating but it would hit a wall at a certain point if the exhaust pressure got too high. I wonder if you would have got 60 more rwhp on tp of the 548? With your thoughts with the 76 GTQ i dont think it would matter as much until you wanted to get more than the rated hp. Though we know those numbers are usually a little high. I think it just matters how much oxygen and fuel you can cram in the cylinders and be able to get it out.Starting to sound like if you built it with nitrous in mind.. the flow of the turbo has to be calculated and the sweet spot for its air flow as well.
My thoughts are you get lets say a 76 GTQ rated at ~950 by Precision. If you had a motor at 650 to the wheels at 25 PSI boost.. and you bumped in a 150 shot.. that should take you to ~850. At 25 PSI boost. Vs going to ~mid 30's for boost at ~800.
I did a little nitrous testing on a 35 shot early last year. a 35 shot=60 rwhp. My engine at the time at 27 PSI made 548. At 25 PSI and 35 shot made 585. Two less PSI, made more power. Turbo I was using was a small shaft 67. Rated at ~700HP. These ratings are flywheel per mfg. So 700x.8(20%loss)=560 approx. Pretty much in the ballpark.
When you crank the HP up.. the exhuast flow will increase.. so if you have the exhuast/WG/DP to handle the flow.. turbo to handle it.. I cant see the negative?
Thoughts..
True, but at what point does the exhuast housing on the turbo become the bottle neck.
Guess it starts feeling like a nitrous engine on an NA. Whereby the cam selects airflow though it.. and a nitrous motor, run NA doesnt run well. Guess the same can be said of a turbo engine, but playing with multiple power adders.. gets tricky.
Wish I had more dyno time.. this new motor has a 71GTQ .85 housing. We'll see how the engine breathes it.. and start the datalogging process..
With a small amount of N2O for spoooling there shouldn't be a big issue it looks like when you are spraying a lot of N2O all the way down the track that you start maxing out the exhaust housing flow and running into issues.Humm I was going to use a small shot of nitrous and add a alky kit to my grand national for next year, Use the nitrous just to spool the 9'' 3400 art carr off the line, Didn't know there was so much trouble, Would the alky and nitrous work ok together
