Can you post some scantool data?
Do the chip/injectors match?
Exhaust leaks?
Faulty O2?
FP too high?
Bad plugs/wires/coilpack?
TPS/IAC settings correct?
Faulty MAF?
Bad grounds?
No scan tool yet, but real soon..
Stock chip and stock injectors as well
I saw a little crack in the driver side header but my WH1 has one way bigger then that and it never seemed to effect it that much, But I think the passenger side has huge cracks cause it is load, but very hard for me to see any on that side.
O2 is new, but it was on there when I got the car......
FP was set at 50psi and it would climb well over 60psi when I gave it gas, I lowered it down to around 45psi to see if that would help and it didn't
I think it may be in the wires and plugs, I think the coil pack has been changed over to the 86/87 setup, but not sure on that. I did notice that the coil pack assybly was not bolted on correctly and I am suprised it did not fall off into the fan:biggrin:
Tps/Iac settings, I am not sure at all. I had spoke to Brad about that and the wife was in a big hurry so I had to cut it short..... Care to explain the settings for me on these???
I don't think the MAF is bad. It looks newer but who knows. I remember when my TA had a bad MAF you could tap it with the handle of a small screw driver and the car would run like crap and you tap it and it would smooth out for a bit. Yes I know that is reall half ass but it does work
Grounds all appear to be there and in good shape.....
I myself am leaning towards the ingition system but who knows. I just don't like the fact that you hit the gas peddle it dies!!!!! And it will idle down so low it will almost die and pull itself back up and then down again....
