Actually it is more than likely the original engine to the car and not a warranty or replacement engine. The replacement blocks were stamped at the engine assembly plant for use in warranty or normal parts sales. Those numbers were used to track its sale to the dealer. When used under a warranty situation then those numbers would be transferred to the paperwork for documentation for the car it went into. Same goes for a replacement engine bought through the parts department, that is how they tracked warranty information to the customer. Now I am not 100% up on the Buick engine stampings for the 80's - up engines, but the norm for the earlier ones was something like: BE4XXXXXX. This stands for Buick Engine, 4 (year: 74, 84, 94, 04) then the serial number for the engine, not a car. When an engine is used in a production vehicle, the vin is stamped by an assembly line worker just before the engine is installed into the chassis. They could have been running behind that day and it wasn't stamped, or the worker just forgot what he/she was doing. Check the cast date of the block and compare it to the build date of the car on the trim tag or door decal. It should precede the vehicle build date by as little as a day, up to a few weeks. This block would be a restampers dream for their 84 GN or T-type................RatPack.....................
