No Fan After Speed-pro Install
gmturbo
Northern Turbo
I have installed my speed-pro and the cooling FAN WILL NOT
come on. I have set the settings in ecu config for 156 low
and 175 on the fan only comes on at 200 f....not sure why
please help.
no fan speed
the part # of the ecu is 30-222311
sorry so late responding..had to pull the ecu out to look at
# on the back.
thanks let me know
FAN SPEED
Thanks for the info
So I guess just wire the fan to a relay and toggle switch
and monitor temp myself? Also can you explain to me
the benefit of the Bank to Bank system over the present
system I have now.
That model does indeed have fan and fuel pump control. That part number is for a dedicated Buick V6 DIS SEFI ECU and has IAC control and Fan, Fuel Pump control.
You should be able to find in the dashboard, the FAN sensor (flag) and monitor it to make sure the Fan is turning on when the FAN sensor says it's on and vice versa. I would be surprised if the control parameter is off that far. Please let me know.
Lance
Thanks Lance
I will look at the dash asap. I will update you
with my findings.....I thought I went a miss on something
thanks again.
