no oil to turbo
flyhigh
replaced turbo before installing checked oil line to turbo stared engine ran 1 min good oil press but no oil at turbo line
It the line kinked? Remove the line from the brass T and see your getting oil there.
pull the turbo oil feed tubing off and see if you can blow through it
your first post stated you had "good oil pressure" , if thats true your readings should be coming from the bras tee ..so i dont understand your second post that you were "puttins oil pressur gauge line to brass t".. ???
maybe its too early to expect posts to make sense .. but where were you getting your good oil pressure reading from ??
What Paul said^^
If you are relying on the idiot lite.....it goes out @ about 4psi.
He's probably putting the gauge up top at the turbo where a lot of lazy people like me put it. ;)
oil line was stopped up problem fixed with new line thanks every one for help quick response
"checked oil line to turbo stared engine ran 1 min good oil press but no oil at turbo line"
1 min no oil to turbo?? I wonder how long that will last? Was the replacement due to previous turbo failure?
previous turbo shot lack of oil line was coked up hi heat cooked oil
