85TurboTtype
It's just a V6!!!!
- Mar 22, 2003
Alright gentlemen, I have a serious problem. First off, I'm not getting any spark. I have read that everyone resorts right to the crank position sensor, but I'll tell you what my situation is anyway. I just purchased a new body for my car because last year I decided to smack into a telephone pole. I pulled my engine out with tranny. When pulling it out I found out the whole tranny case was cracked (ouch). That really sucked, but is besides the point. Anyway, I have the engine back in the car now and have absolutly no spark. First question, When checking for spark the plug must touch ground somewhere right? Next, would my crank position sensor go bad because of a collision? Which wire should I check at the coilpack to see if there is juice/power there? If there is power at that point that I check at the coilpack, does that mean the coilpack is shot?
Second issue
When does fuel pressure show up? Does the fuel pressure show up right when you turn the key forward? If I'm low on gas will there still be a pressure reading? If I know I'm full on gas, what could cause no pressure? I do have a hotwire kit and I've checked for power at the back connection point and I have juice there. (Allthough it only seems to be like 10 volts) When I purchased the car, I was told that there is a Walboro 340 pump in the tank. If the car sat long enough would/could the pump have frozen up?
Also what is the story with fusible links? I've heard that they are good as long as they are firm, not sloppy or squishy?
Last note- The car does turn over, so there is power at the starter. When I turn the key forward I have power at the stereo, but have no interior lights..... Not sure on this one...The horn works and so do the headlights/highbeams/turnsignals.
Any help with these matters would go much appreciated...Thank you guys in advance!!!
Second issue
