I had just finished pumping a full tank of 93 into the GN, then I went to start the engine, it ran for just a few seconds then died. I could not get it to start. It sounds like it wants to start, kinda like I need to pump the gas as if it were a carburetor vehicle. Battery is fine, Scanmaster shows everything is well. I happened to have a spare coil pack that worked fine when I removed it. So I installed it and I have the same issue. After checking the spark plug wires (with both factory coil packs) I did not see any spark. I assume this is an ignition module issue, and I intend to buy one and install it this weekend when I have time. Anyone had this happen before or have any other ideas what this issue may be?
