No Spark!!
Major Nutz
Ok,trying to make it to the Noble shootout, but it's not looking good:( New engine is in but no spark from the coil pack. It acts like it's out of time, but it should spark at some point. All the other electrical seems fine. Could a module go bad from just sitting? How do I check timing at the crank sensor? Any help is appreciated.
Thanks,
Mike
I've had an ignition module go bad before without any sign of it doing so.
I pulled into the garage after driving the car fairly hard at about 10 pm and go out the next day and it wouldn't start, turned out to be the module.
I don't know if you seen this but it may help you troubleshoot the problem.
No Start Diagnosis - Page 1
good luck with it and hope it's not anything major.
John :smile:
