No start, got fuel and spark
GDNF2ET
Car sits in storage all the time and I start it once every 2 months..Took it out and poured some seafoam in it and put 4 gallons on top of it at a station..Drove the car for about 8 minutes and it shuts off like its outa gas...Got it towed home,I am getting spark, fuel pump is pumping, fuel is at rail and pressurized, starting fluid sprayed at open throttlebody WILL make it fire and try to start...
1) changed the crank sensor, no start
2) pumped out all old gas through the rail and put in 2 fresh gallons of 93...no start
Help me
Well, the 15 amp fuse was blown under the dash :rolleyes: Not sure if that was the cause all along or if I got careless with the jumper, but I wish I was smart enough to have checked that 1st...Now I have to worry about why it blew...
The oil pressure sensor was un-plugged.. The plug with 3 wires melted together and caused a ground situation...
