Need help from the experts. Started engine on Father's Day weekend and ran fine for 4 minutes (shut down because did not want coolant temp to go above 143 and trigger ecm.). Just wanted to check for leaks and loose stuff.
Tried to do the same next weekend and got no start. I have been following the no start tests available at vortex-buick and find no issues. Here's what I've done.
1. Originally thought it was a fuel pump issue. With the help of BlackBandit discovered the fp relay was switched with ac relay. With new fp relay (and
no longer needed new ac relay) now have 2 sec pulse at ign and cranking fuel pressure at 20 lb.
2. SES at prestart ign continuous on. ALDL tests for 12 and no other codes.
3. Double checked cam sensor. Used my leakdown tester with a balloon to make sure I'm at TDC of compression stroke. Advanced crankshaft to 25 degrees atdc (added mark to balancer for 25 atdc). Reinstalled new cam sensor with sensor gap at 4 o'clock position from front of car and +7 volts to 0 off terminal "B" of cam sensor places cap leads at the 4 o'clock position as well.
4. +12 from pin "P" of 14 pin connector to ign module. Also get +12 at both ECM fuses in fuse panel. Fuses good as well.
5. +12 to pin "C" of ign module connector triggers injectors (pretty neat design with all injectors firing at once).
6. Jumper B and C of cam sensor harness followed by jumper B and C of crank sensor harness triggers injectors as well. +12 at terminal A of crank sensor harness.
7. 0.025 inch clearance on both sides of all three blades for crank sensor.
8. Checked/replaced coil pack.
From what I can determine all the electronic/fuel tests appear to pass the no start protocol. Seems that the ign module is all that's left, but I'm looking for suggestions about what I forgotten, ideas about what to do, or ways to determine if it is the ign module.
Hope to get her started before next Father's Day....
Thanks,
DGC
Thanks,
DGC
