no turbo
Haynesie
I did a search but didnt find much, what if any problems will occur with running no turbo for a very short time period, wouldnt it all work out fine if i put the oil feed line in the oil return line and just created some sort of pipe to connect from the header to the downpipe?
You don't want to put the oil feed line into the return line. Just cap it, otherwise, your oil pressure may drop. Cap the return also, obviously.
If your still running a chip or even with a FAST if you get into PE based on TPS, which isn't hard to do, things are gonna get pretty rich in there with the additional fuel and no air. At least with no boost you won't have any fuel pressure rise so that will help a little. And the FAST will belooking at map so depending on whats in those table values.....
WELL im just thinking in terms of being able to keep the car running while the turbo is off, to make sure no seals dry up, i dont plan on driving it, just running it for a few minutes at idle, i plan on rebuilding the turbo, i dont plan on driving around town, just keeping everything lubricated and making sure no more things dry up...thanks
