No VSS signal to Computer
Haynesie
Hello,
Recently I lost signal the speedometer signal going to my ECU from the buffer. This occured a few month ago randomly, and since I planned on converting converting to a new gauge cluster and would be utilizing the Caspers pickup and buffer (link below), I figured no big deal since it was probably just the stock green box under the dash going bad.
However once I installed the new caspers unit, which is plug and play, I'm still not seeing speed show up on my scan master, and eventually the ECU throws a code. I've tried the following things, but seem to have no luck:
1. Check that the new caspers unit is connected - I have a red light on the module
2. Tried disconnecting the sendor from the speedo cable to see if it would read a signal if I manually spun it (with car running), but there was no speed registered
3. Checked the voltage of the caspers wiring harness at the sender - there is about 4-5 volts when I test the red and black wires
Anything else that I should be checking? a bit lost at this point.
Thanks,
Jason
Hello,
Thanks,
Jason
Call Caspers and talk to them.
Clearly that’s an option, but given they are closed on weekends, was hoping someone could share some actual advice based on them having an understanding of how the system works.
Unde rstood ,
