I can not get my wide band o2 to work, It is not showing up on the bottom right corner of the screen ! Also i can not get the computer to go into closed loop. I have all the setting set so it should turn on at idle. There is no o2 correction going on. All the requiremtns are met. Temp, rpm and time . So what is keeping it from going into close loop. I read some other post about this. And there was mention that it willl not go into closed loop if there is any after fuleing corrections. So i looked at the graph and the little cross hair is at 180 degress and +80 enrichment. Please help!!!
Micah
Micah
