NON computer controlled distributor for a 1986 3.8 N/A motor??
Ted
Anybody have an HEI that doesn't need a computer input?
Thanks,
TD
I have one on EBay, has been there a few days. Not much interest in it, but the auction has started. My last one went for $25 without the coil I think. If you want it I will try to cancel the auction, or you can bid. Item number 7970298409, user duck_truck84
Squid
Sent you an e-mail. I would like to get a hold of it, if at all possible.
How much you want outright with coil, module etc, ?
I read somewhere that you can use a distributer out of a chevy striaght 6 -250 cid motor common on trucks and in chevy vans for your application. let me know if you need some headers or true dual exhaust for it- i have a set.
What's the difference between a computer and a non computer controlled HEI? I just pulled a dist out of an 85 Regal at the junkyard to use as a get it running ignition with my 4.1's carbed manifold and now it won't work?
Thanks,
Thanks,
Non Computer controlled means it has a vac canister, and centr weights and springs in it.
I beleive, there is an even and odd fire dissy. The early being an earlier version, and they'll both drop in.
