Well the last few weeks been a bit busy. In the middle of this I wanted to start doing some testing.. Unless I have data I cant say whether something works or not.. So here goes.
A little background..
My car is an 89 Mustang. Yeah I know.. I got the Mustang trying to get more marketshare as 90+% of the kits I make are for GM vehicles. I applied what I have learned working and tuning on the Buicks on this setup. The computer for example is the FAST XFI I had on my TTA. Motor was assembled by me in my garaje. Off the shelf pistons JE's, Speedpro rings, Clevite bearings, nice 4 bolt A4 block, Holley heads with some mild porting, 60 lb injectors, etc. heads are o-ringed and I use Ford graphite gaskets(40.00). Car is used to run in True Street which requires 30 mile cruise.. and 3 back to back runs.. for an average. In 2010 it averaged 10.17. In 2011 it averaged 10.04 for the 10 sec class win. At the time it had a 76 Turbonetics turbo with a .96 housing. Steel headers from a company called Pony Down. The turbo was having too much back pressure and I realized it needed a larger turbo/housing. As of April 2011 it had run a best of 9.68 at like 142 on a 1.42 60 foot 20 PSI boost. I swapped turbo from the T4 76 Turbonetics to a T4 Precision 88 .96 and the car instantly picked up. At 16 PSI it ran 9.4 at 145. At 20 PSI it now has broken the 150 MPH barrier. And has now run 9.21 at 148.xx on a mid 1.4 60. Here is a temperature log from that 150 mph run.
It showed 118 degree's through the traps.
