Non-Lock up conversion.
paulg
A chase is a race.
Calling Trans experts. Need help. I have a stock 200/4R with the D5 in it at the moment but now have a 2800 Non Lock Up convertor for it. What changes need to be made in order for this to work. I found a "conversion kit" TransGo makes but want some more input before I drop the trans or even buy anything. Any and all help is appreciated. Thanks.
PaulG
It should have instructions but,
Remove the stock TCC valve, install the Non-Lockup Valve in the Pump.
Remove the Cage & Checkball + O-ring from end of the Input Shaft.
The TCC Solenoid can be removed or left in place.
