NOS assisted launch
tom j
After 5 passes of getting the nos to work properly and figuring out how to launch the car. I was either spinning really bad out of the hole or to soft of a launch and spinning about 80ft out when the nos really came on. So I started out shutting the nos off at 180kpa and came to realize it was to high for the car to hook. My final pass I turned the shut off to 149kpa and left at about 4psi and it finally did not spin:D the bad part is sometime before the 1/8 my rear view mirror came off and hit me in the helmet causing me to let out before the 1/8:mad:thats why I think my mph was so low. Anyways at least I have a baseline. This is with a 88mm turbo and a 3000 stall.
60 =1.65
330=4.16
1/8 =6.24@111mph
I'll get some video up later when I get it from my buddy.
Real strong run.. Dr Boost is gonna have his hands full :D
You need to get that 60 down.. that is a function of apply power which you have, suspension, tires, and boost control.
It's a 100hp shot and 24-26psi. The time it took to reach full boost was 2.2sec. I only was able to do one run with the nos shutting of at 149kpa I think that it will be a decent point to leave it and just leave with more boost in the 8-10 range. I also did a pass with no nos just to see how it felt on the big end I let out about the 1000ft mark and it went 142mph at 11.70
