Ok, just got back from the track. The place I usually get race gas was out, so I go just to get some 60ft practice. I ran a thrasher92, and 15psi, a used set of ET streets, totally stock suspension. The best I could muster was an 8.82@80mph with a 2.05 60ft. I wasnt expecting a killer ET on pump gas and a thrasher, but it should have run mid 8's anyway. I tried 20psi and worked my way down to 16 on the ET streets and my 60's got worse. Usually a 2-3psi launch. I think I was hooking right off the line and spinning after 4-5feet. I know I was spinning because I got some false knock at 5-10mph on the scanmaster recall. What am I doing wrong here? I burned the hell out of them and I still slip off the line. Any tips or advice appreciated, also, how does that ET look considering the pump gas and slow 60fts? Thanks in advance and sorry for the long post,
pat
pat
