Hello
Car died on the way to work, just cranks over. I had towed home. Got some feed back on this site on possible fuel pump relay or pump itself. put in a new fuel pump relay. still wouldn't start. check fuses, use test light got power at emc(pink wire) to relay and check the plug by tank, got power. even used jumper wire behind alternator and pluged into hood light, can hear pump run. still nothing. is there any other electrical issue I should look for? is there a main module or relay gone bad. I do have spark and checked the fuses and even use test light to verify power with key on. I do not have a hot wire kit, all stock. do I need to recheck something. is there a volt issue somewhere. thanks for your time
