In addition to the above, the good book of Buick suggests :
- Replace IAC gasket
- Clean the throttle body bore
- Check injector balance
- Check TPS volts .36 - .44 (need a scan master)
- check crank sensor for contact with interupter. if signs of contact replace sensor
- Reset IAC while motor operating temp at by:
- start engine & run for 10-15 seconds then shut off for 30 seconds;
- start engine, engine in gear, AC off check IAC count on scanner. If less than 25 replace IAC.
