Russ Merritt
- Aug 11, 2002
Russ, Grumpy has nothing on me as far as procrastinating. Although I do have plans to do a little more work this upcoming weekend...
Your right........I take it all back.....
all i gotta say is welcome to the other side .. " the non c-16 side "
yullose maybe me and you will have to get a pass off on your local road......
Did you find any......I'll tell you what... I'll be driving the car a whole helluva lot more now that it doesn't have a tank full of C16 in it.
You don't know how many times I walked into the garage and wanted to drive it to work... Only to say... NOPE... Not with $13/gal fuel in it.
I drove it around last night for an hour looking for trouble.
Cheapest performance adder, PERIOD!
Estimated 8HP/lbs of boost increase (estimated)
Boost increase w/alky 10 PSI (easy)
HP increase @ 10psi = 80
Kit cost $500 (est)
At $6.25 /HP = No brainer/Untouchable. :biggrin:
Buying a proven TR kit, another no brainer.
Getting AWESOME service and TECH supprt, another no brainer.
Spanking other cars on the road = Priceless
Bring it up our way when the weather warms up. There's always some action going on.
Excuse me, other than FLAT OUT top speed Banzai Runs on the Reading ByPass theres ZERO action up here...now 20 miles South down futher on 422 ~ Pottstown, yea...
I've been going through Street Racing withdraw up here for 5 years now, coming from Northeast Philly and the Roosevelt Dragway!!! :biggrin:
The best "Test strip" I've found is the long concrete road that passes in front of the Oley dairy. I can do a few quick 1-2-3 short passes in my neighborhood on Carsonia Ave., but if I really want to run it a solid 1/4 mile, I 'gotta drive out to the dairy.
Yup, I use that SAME Stretch fot T & T....and thanks for Finally Confirming what I've always seen, when I first moved up here in 2002 I would drive around for hours on a Saturday night (burning up ~10gals of C16) looking for the local Race Hangout...oh well...
GET IT NOW !!!
I ordered a dual nozzle kit from Julio... The Brown truck delivered it Friday.
I had all the underhood work done Friday night, and finished up all the underdash wiring today.
After a few test runs, I've got it pretty well dialed in... and all I can say is...
DAYUM !!!!
I can honestly say, the car feels as good, if not better than it did on C16 race fuel. I'm willing to bet the car will probably beat the race gas times it put down in November... If I had to make an educated guess, I'd say the car will run somewhere in the 10.70's-10.80's the way it sits now... on pump gas and Razor's alky system.
I didn't get the alky chip from Eric yet, so I made some adjustments to the 93 octane Street chip. I added 15% more WOT fuel to compensate for the 29 degree temps, and added 4.2 degrees of timing.
I only ever saw 1.4 degrees of knock on my first test run... So all I did was turn the knob up just a tad... and poof ! no more knock.
Boost is at 27 psi, O2's start out around 820, and settle down in the 780's at the top of 3rd gear.
I absolutely cannot believe how well this Alky stuff works.
Julio... You DA MAN !!!
If any of you guys are still "on the fence" and haven't decided to go with an Alky kit yet... What are you waiting for ?
This kit is without a doubt, the best $500 I've ever spent.
Your gonna love it! I was going through one to two gallons a week of methanol when I was daily driving. It is the shizzle! And..... Julio is the man.
Two thumbs up for Julio!
I have been on the fence for a while about giving alcohol injection another try.
After much observation and deliberation,I have decided to give Razor's kit a try.I think his methanol injection is far better than the old setup I tried.I am impressed with what has been done with it.
I picked up a turbo T that I am putting a cheapie 4.1 together for,and as soon as I get the basic combo together it's getting a kit.
Should make for a fun street ride with good AC and no overheating using a stock location intercooler.I just want to maybe run some high 10's ,and from what I have seen,that's no problem.
Surprise,Razor!
