I have the m15 nozzle, 24lbs boost, 23* timing, 11.3 afr and the car mph highest with the alky knob set on 4 go higher and it slows down, this is on 100% meth. I have seen posts where Julio has said this lower setting may not give the best pump performance. So how should I tune to get to a higher pump setting? or should I go to a smaller nozzle?
Stock motor, TE 60, 50lb inj, MAFTPro, LC-1
Thanks,
Mike
Thanks,
Mike
