OmahaKnight
Collector of money pits
- Apr 6, 2003
I've been having a problem for a while with my car dying on me and not restarting for a while. When I drive it for more then 10 minutes, turn it off, then try to restart, it wont' start. It'll constantly turn over but not start. After anywhere from 10-20 minutes, it'll start back up. Well, I thought it might be the MAF and IAC motor so I replaced both those from NAPA. Now it runs worse!! Now when I'm driving, the engine will cut out on me, not die, but cut out and sputter really bad like it's getting no fuel, and I have to really ease into the throttle in order to accelerate. I replaced the MAF on tues, and noticed my IAC #s were in the 70-90 range so i replaced that thinking it would fix it, it didn't. The only thing I've noticed is when it starts to sputter and cut out, my MAF readings will go from 25 to 250+. These are the scan master readings I took while it was idling at 800 RPM after lunch today.
AF 05
L8 37
INT 128
BL 111
ATS 91-97
RPM 800
TPS .44
IAC 21
cc 137
O2 was from 400-875
Any ideas? As of right now it's my daily driver so I need it fixed asap!
			AF 05
L8 37
INT 128
BL 111
ATS 91-97
RPM 800
TPS .44
IAC 21
cc 137
O2 was from 400-875
