O2 numbers fluctuate a lot on PL...
rcantu
still new to using it but at idle it fluctuates a lot. i'm getting code 45 rich o2 sensor too.
i'm guessing it's a bad sensor?
see my screen shot.
thanks
That is perfectly normal for narrow band O2 operation during closed loop.
You have a very healthy O2 sensor there. When the ECM is in open loop (WOT, or cold engine, etc) will you see steady readings.
And don't worry when at times during deceleration you see the value drop to zero, that's normal also.
thanks for the help.
i'm wondering why i'm getting code 45 "rich o2 sensor"
too much fuel pressure?
If you clear the computer, does that code keep coming back??
post a screenshot of the data page with your BLM's etc.
Bon
